09-10-2021
05:41
10:39
09-10-2021
05:41
10:39
Hi Everyone
I’ve had my sense since December (having previously had a versa) and have found the heart rate monitor is terrible like way off what it should be comparatively to chest straps/heart rate monitors at the gym etc. Like, I’ve never hit my peak heart rate on my sense! And generally there is a disparity of at least 40-50bpm compared to other methods, even a different fit bit. I know they are never 100% and in fact nothing is ever 100% but still I’d expect to be nearer.
anyway, Fitbit have some suggestions to try which I did for two weeks but no joy. And from having a look on the community it seems this is not an uncommon issue with the sense.
fit bit have been good they’ve offered either a replacement of the sense or 50% off any other module. Has anyone had a similar issue then replaced with another sense and had it work?
im just not sure what to do as I’d hate to get another sense and be disappointed again.
Best Answer09-10-2021 10:48
09-10-2021 10:48
Hi, @Mishb233. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Sense. We‘re taking your comments and sentiments in regards to our products and services into consideration.
Our products are indeed designed and made to last (this goes for each product component) however, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our Warranty Policy is set into providing as much coverage as we can.
We understand that the outcome of your case with our Support Team is not fulfilling your expectations, but keep in mind that every case is completely different from the others. Thanks for taking the time to share your experiences and feedback. For more information about the outcome of your case, please get in touch with our Support Team again or you can also check our warranty policies here for a better understanding of the information you were provided.
Thanks for your understanding. Have a good day!
Best Answer09-10-2021 10:53
09-10-2021 10:53
I think you need to re-read my post, as you’ve totally missed the point.
I actually said FitBit have been good with my enquiry. What I’m wanting is advice from others who have had a similar issues to myself. Do I try another sense and hope I don’t have the same issue or elect to take the offer of 50% off another type of Fitbit.
I really don’t think you should be commenting on behalf of your company if you don’t fully understand the post.
