09-05-2024
13:04
17:35
09-05-2024
13:04
17:35
So my Fitbit Sense lost communications with my cell phone. I had the bright idea of shutting it down. Now I can't turn it on. I try holding or pressing that so-called button and nothing happens. I tried holding or pressing the button with the charger charging it and nothing happens. It's dead.
Best Answer09-05-2024 14:53 - edited 09-05-2024 14:54
Hey there @frankliemydear, thank you so much for being part of the community.
I'd like to give you a couple of tips to get your issue resolved, please let's start the troubleshooting.
Based on what you have mentioned, it seems that this situation is deeply related to a charging issue. With that said, I just have to thank you for the steps you have already tried.
As a first approach, I would like you to try cleaning the charging contacts on the back of the device using a toothbrush and a small amount of water. You should also clean the pins on the charging cable. Use a cotton swab and some rubbing alcohol, making sure no cotton fibers remain on the pins.
Finally, you'll need to connect it to a different USB port or a UL-certified USB wall charger.
Best Answer09-09-2024 08:45
09-09-2024 08:45
Thank you for responding. I don't think it had to do with charging. The Fitbit was 85% charged when I shut it off. It just won't turn on. I've been told those fitbits do go out and this one was more than two years old. So I've purchased a new one. I've also watched the video someone did (maybe it was you) where they cleaned the charging contacts, but again, the charger was working fine. In fact it was a new charger as my old charger stopped charging the watch earlier, and I did all those steps you mentioned and it still wouldn't charge. When I purchased a new charger, it started charging again.
