05-30-2022 15:34
05-30-2022 15:34
Hello,
My father-in-law uses the fitbit Sense and we have noticed that since he started using an assistive device to walk (i.e 4 wheeled walker, rollator, etc.) he cannot capture his step count accurately even while in hike, walk, and run mode. I was wondering if there is an update or advanced setting we can use to better capture his new step count per day? I know Fibit uses your step length and arms swinging motion to capture steps/running/walking but he will no longer be able to swing his arms and will have to hold on to his walker.
Warm Regards,
Brittany
Best Answer05-30-2022 16:19
05-30-2022 16:19
If he had a definite forward arm motion with each step, that might get captured as steps, but not if steady forward motion.
For step count, he would probably get a more accurate count putting it in a pocket. But then you lose all heart rate data.
With it on wrist, though not getting step count, you would still be getting heart rate data and its associated values such as calorie burn.
06-15-2023 11:37
06-15-2023 11:37
Hi,
I'm finding that while I can't get a step count, my walks are being classified as bike rides, but the GPS tracks the distance so I can extrapolate from that. Good luck!
