02-25-2025 19:40
02-25-2025 19:40
What features does the Sense 2 have over the Sense 1? Have any features been removed? What improvements have been made?
Best Answer02-25-2025 20:53
02-25-2025 20:53
Hi @raj0640 - the Sense 1 has features that the Sense 2 doesn't, like apps, Google assistant, more clock faces, etc.
As they are using different operating systems and user interfaces you will need to check which features you wish to use that fits your needs best.
Best Answer02-27-2025 08:55
02-27-2025 08:55
@raj0640 There are two reasons why I do not recommend the Sense (original)
Laurie | Maryland
03-01-2025 02:13
03-01-2025 02:13
My advice is dont buy Sense 1 . I am ver y dissapointed with mine. The batterylife is useless,it needs charging at least every 24 hours and that is using it with all the battery saver options suggested.If I set it up and use it how I want and use all the features,I would be charging it twice a day.
Best Answer03-01-2025 03:48 - edited 03-01-2025 03:50
Hi @Jomac151 - it seems you are having a problem with your Sense 1, it would be a good idea to make a separate post as to what the issues are in case there is a fix for it, because what you are experiencing is not normal for that watch, mine lasts easily upto 6 days. Here's a typical example
Example days days betweeb charges
Best Answer03-01-2025 11:16
03-01-2025 11:16
Where can you find that information? I don’t see it on my sense
Best Answer03-01-2025 11:28
03-01-2025 11:50
03-01-2025 11:50
Well they just destroyed the Sense battery life with the mandatory firmware update. I have all calendar, text, etc turned off and I used to get at least 6 days before charging. Now it's 2 days.
