Should the Sense vibrate at 10,000 steps?
Not sure if the sense vibrates at 10,000 steps or should it ??
7 REPLIES 7
Hi @keithys -  if you set your step goal to 10,000 and synced the watch it should vibrate and announce when the target is reached, unless
  • Swipe the watch face to the right to get to Quick Settings and make sure sleep and Do not disturb aren't enabled
  • in the Fitbit App  click profile photo, Notifications and check your push notifications are correct
@keithys Welcome to the Fitbit community.
It should alert you at 10,000 steps. I got my alert yesterday. It gives very long vibrations and shows on the screen.
More possibilities:
Is your step goal actually 10,000?
Is that your main goal?  It vibrates for main goal which you can set to various stats.
 I found out why when i turned of night mode thanks for your input
I found the reason the night mode was on but thanks for your reply
Thanks guy that was the reason for the no vibrating at ten thousand steps
@keithys51- thanks
