06-09-2021 11:27
06-09-2021 11:27
Has anyone else had this problem? When I open the app and go to my sense and clock faces, all it says it that "opps looks like there's no Internet Connection". I've checked my connection in other ways and it's fine.
Any ideas on what's wrong?
Best Answer06-11-2021 10:41
06-11-2021 10:41
It could be you have security software or ad blocking on your phone.
In case it's a WiFi/router problem, try turning off WiFi on the phone and just use your mobile internet.
Best Answer06-09-2021 23:59
06-09-2021 23:59
Could simply be a glitch in the App.
If a shutdown of the watch and restart of the phone does not fix it, try
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
Or for IOS uninstall/reinstall the Fitbit App, and redo all notification setup. |
If the clock you want is already installed on the watch you can swipe right edge to the left till you find the Clocks app and change it there.
Best Answer06-11-2021 10:09
06-11-2021 10:09
Thank you for the suggestions. I tried them but unfortunately it didn't work. I'll keep trying to figure it out.
Thanks again.
Val
06-11-2021 10:41
Best Answer06-11-2021 10:45
06-11-2021 10:45
That was it. Thanks.
