12-25-2022 14:18
12-25-2022 14:18
I used to be able to expand this chart to see detailed heart rates and time of day each data point was recorded. As of some software update (last 6+ mths?) I can no longer access this level of data on the chart. I can only see the start and end time for the sleep session and the heart rate values. The times of day for each value are unavailable/missing. I would live to see this fixed or otherwise brought back to this particular chart. Thanks!
12-25-2022 14:24
12-25-2022 14:24
Hold your finger down on the chart. While depressed slide your finger should show time.
12-25-2022 14:24
12-25-2022 14:24
12-25-2022 14:39
12-25-2022 14:39
I know, right? This *used to be* the case. Now that method no longer works. Only the heart rate value (e.g. 65) — and not the exact time for each rate — shows.
12-25-2022 18:10 - edited 12-25-2022 18:11
I am still able to pull up the rate and corresponding time for both sleeping heart rate and resting heart rate using that method.
If you walk me through the steps you are taking,
we can compare results.
