My sense the last few days isn’t showing stats (pace, HR, steps, etc) when using the exercise app… more specifically “run” and “walk”. The middle of the screen where it used to show is now blank with a small distance tracker at the top. Help! I rely on seeing these stats during my runs.
Best AnswerAfter you select Walk or Run in the Exercise App, swipe up from the small arrow at the bottom of the screen to see more options. One option will be 'Show Stats" where you can select what to show in the top, middle, and bottom of screen.
Best AnswerThanks for the response!! I checked and all my stats that I would normally see are still selected. I’ve even restarted the Sense. 😞
Best AnswerDon't know. Maybe try changing the stats displayed to something simple such as time, for a fake test run to see if that makes a difference, just to see if will display something there, even if not the stats you want.
The stats that are not showing - d they show up in summary? Could they all be related to same thing, such as not getting heart rate or such?
Best AnswerIt shows my stats on the app after it syncs. Tried taking off all the stats, restarting, then adding them back but still nothing. I took a pic of it but not sure how to post on here.
