06-06-2022 06:37
06-06-2022 06:37
Any ideas?
Best Answer06-06-2022 07:32
06-06-2022 07:32
I got it to work.
The step count is only off by one now.
06-06-2022 06:43
06-06-2022 06:43
Hi @Acceptable Sync the watch a few times and hopefully it will match up shortly. If it still doesn't then restart your Sense and sync again. That usually works for me.
Helen | Western Australia
Best Answer06-06-2022 06:46
06-06-2022 06:46
Hi @NellyG How do you sync the watch? I only know how to sync the app.
Best Answer06-06-2022 06:50
06-06-2022 06:50
I've tried:
The app and the Sense still have different step counts.
Best Answer06-06-2022 07:02
06-06-2022 07:02
@Acceptable Open your app and the app should try to sync tonthe Sense. If it doesn't, use your finger to pull down on the home page. It will say release to refresh neR the top. Remove your finger and itmwill start to sync and say 'syncing your sense'.
Or go to your account page (account icon on the top left of the home screen) and go to 'Sense' around half way down the page. It will tell you when it lasted synced and you can initiate a sync by tapping on the Sense pic, and on the page that comes up tap Sync Now.
Best Answer06-06-2022 07:11
06-06-2022 07:11
I've tried:
06-06-2022 07:18
06-06-2022 07:18
@NellyG adding the exercise is the root cause of the step count on the app and the Sense being different. The Sense has the correct step count.
I've never added an exercise that involves steps before, I've only added Cardio Sculpt. Adding that works fine.
The auto-recognized walks have N/A as the distance. When I manually added a walk it insisted on a distance so I used the miles which the app displayed.
On the app the walking exercise I added shows my pace is 22' 13" which is not possible.
Maybe if I delete and add the walk back and put a tiny distance like 0.001 km it will not mess up the step count.
06-06-2022 07:32
I got it to work.
