10-12-2022 12:48
10-12-2022 12:48
Set that stop charging waiting five days on a solution And no response only six months old
Best Answer10-12-2022 16:10
10-12-2022 16:10
Did you check the pins on the cable?
Best Answer10-13-2022 05:41
10-13-2022 05:41
Hi @timcstc I am a bit confused about what you have done to resolve the issue. Did you contact Support,and they havent got back to you? If that is the case then contact them again. Fitbit Support If you want help for your Sense not charging, try THIS Help Article on charging problems
Helen | Western Australia
Best Answer10-14-2022 08:22
10-14-2022 08:22
