04-18-2021
19:13
07:18
WilsonFitbit
04-18-2021
19:13
07:18
WilsonFitbit
Make available to rotate to watch face so you can have the button on the hand side if you wear the watch on the left hand.
04-19-2021 10:02
04-19-2021 10:02
@Dran9260 @grace3232 Users have asked for the ability to rotate the clock face ever since Fitbit made its first device with Quick View. The Quick view only works on one direction. Fitbit doesn't seem to have plans to change this.
Laurie | Maryland
04-24-2021
07:21
10:25
04-24-2021
07:21
10:25
Hello @Dran9260. Welcome to the community forums! @grace3232 @LZeeW It's great to see you around! @LZeeW Thanks for your input!
While an option to rotate the clock face isn't available, I'd recommend to post this idea in the Feature Suggestions board so our developers can take it into consideration for new updates or product development. Our team strives to improve the Fitbit experience based on our members feedback and I'm sure your comments are taken into consideration.
If you find that a similar suggestion has already been made by another member of the community, you can vote for their idea and add your comments.
See you around.
