11-08-2021 21:58
11-08-2021 21:58
I wish Fitbit can improve on the goal settings for swimming. Instead of having just one vibration (be it normal or strong vibration), Fitbit should allow setting numerous vibrations. Simply because when you're swimming, the one beep vibration cannot be felt, as the water current overwhelmed the vibration. This needs to be improved.
11-09-2021 00:32
11-09-2021 00:32
Hi, Agreed, though if the vibration wasn't so weak on the Strong setting it might help. It gets weaker with decreasing battery level.
