12-05-2021 08:25
12-05-2021 08:25
My Sense, like so many here, has not worked correctly since I got it. I get an SPO2 reading every 8 days, which is the reason I bought it in the first place. But in the meantime I just bought an iPhone, moving from an Android, and now the iPhone can't find the Sense or let me update the tracker, although it says that it is syncing. Do I need to delete the Sense and reinstall it on the iPhone? I don't expect it to work any better but I need it to lodge a report with Support again. Thx
Best Answer12-05-2021 09:27
12-05-2021 09:27
You should only have to download the iOS app, log into your account and then link the phone to your Sense. No need to delete it from your account. You might want to uninstall the Android app from your old phone first.
12-05-2021 10:06 - edited 12-05-2021 10:15
Make sure you remove the device from the old phone if keeping, by removing it from Bluetooth and remove sense controls etc from the old phone.
That may be why it cannot be found or trouble syncing. Conflict with old phone.
See Rich Laue post
https://community.fitbit.com/t5/Sense/Process-to-move-sense-from-old-to-new-phone/m-p/4965077
Best Answer12-05-2021 11:34
12-05-2021 11:34
I have the app on multiple phones with absolutely no problems at all.
