The battery of my Sense is dying
Can you or anyone help
Moderator Edit: Clarified Subject
7 REPLIES 7
Hi @Jojov, welcome to the community.
If the battery life of your device is draining too fast, I'll recommend trying the tips described here: "Can I extend my Fitbit device's battery life?". In case none of the recommendations improve the battery, you can always contact our customer support team to get a prompt and suitable resolution.
I have same issue maybe last one month. It used to last 4-5 days. Now just 30 hours max. Not sure if it is sync issue with IOS related or something else.
Can fitbit reply to our messages here? I need to charge sense everyday now. Sense is loosing 70% of the battery every day.
Hi @uyeveuye, it is nice to see you again in the community.
I'm sorry for the delay in giving you an answer, we are experiencing a high volume of inquiries right now and estimated wait times will be higher than normal.
In some cases, the power source you use to charge your device can be a little lower than recommended. With this in mind, my recommendation is trying to change to a different USB port or a UL-certified wall charger.
Here are some other tips to improve the battery life of your device: Can I extend my Fitbit device's battery life?
Hi, I have tried everything recommended in these forums and in your above article but my Fitbit sense is still draining from 100% charged to dead within hours. Is this now a warranty replacement issue and if so what do I do to get the replacement as my device is still within the warranty period?
So there is nothing wrong with the hardware or software. All I need to do is do same things I have been doing over and over. Also I need to get a flight to USA find a UL certified wall charger came back to UK. That means every fitbit customer in the world should do same. Is fitbit too tight to give UL-certified wall charger?
Get real please.
Hi there @uyeveuye @Bluebird1. Thanks for confirming you have followed the steps previously recommended.
Since the steps have not been helpful for you, I would like to request a case for each of you with our Customer Support team. This interaction is going to be via email. They should ask you for some extra information, so I recommend keeping an open conversation with them.
