The suffering of changing the watch face every night.
Already two nights I forgot to switch to the SPO2 watch-face to track the oxygen level, within a week.
15 REPLIES 15
I, too, got tired of changing it, and now just leave it on the SpO2 clock.
But the SpO2 face doesn't give show your sleep score, which is just silly.
Lol. likewise.
Yea, this is getting tedious. Go here to vote to get Fitbit to change this silly design: https://community.fitbit.com/t5/Feature-Suggestions/View-SpO2-in-app-and-don-t-require-SpO2-clock-fa...
Do you mean if i sleep with SpO2 face clock the watch won't track sleep & I wont get the sleep data next day?
Try setting an alarm on your Sense for awhile before your usual bedtime to remind you to change it. I do that (mine is set for 11:30 p.m.) and it really helps!
Original Flex (March 2014); Charge HR; Alta HR; Original Versa; Inspire; Sense; Charge 5; Inspire 2
Thanks for the tip. It helps but I hope they'll offer a permanent solution to this.
plus the sleep score is not accurate either. I woke up this morning at 6:40 AM, turned the sleep mode off and put my watch on the side. I then wore the watch back at 7:46 AM to go with with daily routine. When I checked my sleep stats, it shows me in Deep Sleep from 6:40-7:46 when I did not even have the watch on. So obviously it calculates the data all wrong. Will try this a few times and confirm but giving wrong stats is even worse than no stats at all.
FYI SpO2 face is consuming more battery than usual, it's in the manual
I confirm. With me it happened differently.
I came back from the gym and before I hit the shower I left the watch on the table. After the shower I went for the watch and I noticed the red light was blinking. It thought I was sleeping .......and tried to track the oxygen level.
Wow
Wait, you have to have the SpO2 face on at night or else the watch doesn't even track the data?  wtf?
I think it'll track Sp02, but it won't show % on the clock face. Either way, it's a really dumb implementation. Vote here to get them to change it: https://community.fitbit.com/t5/Feature-Suggestions/View-SpO2-in-app-and-don-t-require-SpO2-clock-fa....
@stellafred I have started doing that too.
I'm wondering if we can us IFTTT to automatically change the watch face for us? Does any know if this might work?
Ionic = deceased. Sense since 25/9
okay an update on this. this morning when I turned off the sleep mode, I waited an extra second before putting the sense down. I saw the red sensor on for a sec and then it turned off. Once I put the sense down and came back, it did not record me in deep sleep (as it did yesterday). So it seems like you have to wait a sec after turning off the sleep mode for the sensor to go away.
On the bright side, I noticed the time whenever I woke up in the middle of the night and it shows me as awake all those times (so I guess it is tracking accurately). Would keep experimenting with it to find the right mix.
