01-02-2022 06:28
01-02-2022 06:28
What is the best way to get to use my fitbit sense. Is there any hints and tips that someone could recommend.
20:13
10:22
01-02-2022
20:13
10:22
Hi @CelticQueen - it really depends on your needs.
The Fitbit App and watch are quite versatile and have a lot of features.
You can choose all sorts of free clock faces from the gallery depending on what you want to see on the watch and also many Apps are available too.
Also the forums are full of tips and solutions. There is a feature suggestions one as well if you need something you don't find.
You'll also find the manual for your watch here which will explain it's many features.
Best Answer01-03-2022 14:17
01-03-2022 14:17
