11-25-2020 16:28
11-25-2020 16:28
I'm trying to set up my Sense to answer my phone (Google Pixel 3a). The "Sense" device is connected via Bluetooth to my phone. I'm able to pair the "Sense Controls." Both my phone and on the watch Settings > Vibration & audio > Sense Controls show that "Sense Controls" is paired. However, whenever I connect the "Sense Controls" device on my phone, it immediately disconnects.
I've tried "forgetting" the Sense Controls on my phone and then repairing, but still the Sense Controls immediately disconnects on my phone. I've also tried resetting the watch,
If I try to make a test call, the phone recognizes a call is coming in, but when I accept the call, I get an error message on the phone "There is something wrong with your connection. Take call on phone.
Any help would be appreciated.
Best Answer11-25-2020 16:45
11-25-2020 16:45
Hi @SunsetRunner you say that sense controls show paired on both sides. That is what you want. You haven't mentioned what phone you have. You then say when you tap sense controls on the phone, it disconnects. On Android that is what should happen.
You want to show as paired on the phone and on the tracker. This way it is a trusted device and when the answer button is pressed the Bluetooth says, you are friend and passes the commend on.
I just tried a test call and when I pressed answer, yes I got the something wrong message. Have someone call your phone.
Best Answer11-25-2020 16:29
11-25-2020 16:29
Oops, meant "Trying to answer phone call on watch."
11-25-2020 16:45
Best Answer11-25-2020 17:23
11-25-2020 17:23
Did you go through the App and select "On-wrist calls"? It goes through the procedure and points out the permission, and will tell you when it is done properly. "Sense Controls" disconnects until it is needed.
11-25-2020 21:59
11-25-2020 21:59
@Rich_Laue, thanks for replying and explaining that the disconnect of the Sense Controls is normal. I did try a call from another phone and was pleasantly surprised that it did work correctly even though the test call does not. I had wrongly assumed that the test call should be answered successfully.
Best Answer11-25-2020 22:02
11-25-2020 22:02
@FloppyDrive, thanks for your reply. I did go through the App and select "On-wrist calls" successfully. I was able to call my phone from another phone and have a successful connection to my Sense watch. I didn't understand that the "Sense Controls" is supposed to disconnect until needed and that the failure to connect from the Fitbit app test call is normal.
Best Answer11-26-2020 05:59
11-26-2020 05:59
Even the Sense doesn't stay connected. It only Connects when requested. This is to save battery life.
Best Answer11-26-2020 09:14
11-26-2020 09:14
When would the Sense disconnect? So far, whenever I've checked the Bluetooth connected devices on the phone, it always shows the Sense as connected.
Best Answer11-26-2020 10:47
11-26-2020 10:47
With android you should see paired, which is different then connected.
The only time I saw connected was when I was upswing the connected gps slurring a walk.
Best Answer11-26-2020 11:17
11-26-2020 11:17
Hmm, that's interesting. I always see the Sense as connected to the phone and the Sense Controls as paired.
Best Answer01-10-2021 15:20
01-10-2021 15:20
I am having this same problem.
The watch is pairing to the phone (Nokia 5.3). Incoming call comes up on the watch and when you press answer, I get a Connection Error message. I then have to turn the Bluetooth off then back on, on the phone the get things working again.
This is very frustrating and not a simple process.
Would love a step by step guide on getting this working as it should.
Thanks in advance.
Best Answer04-25-2022 14:28
04-25-2022 14:28
I tried this it DID NOT WORK BUT.....
ALL of the recommendations failed to include a note about NOTIFICATIONS.
YOU MUST
Open Fitbit App.
Click on Gear Upper left corner in Android
Select the Sense Picture
Scroll down to NOTIFICATIONS
Turn ON Calls,
Go To APP Notifications
Scroll Down to PHONE
Check the box
Back out leave the APP open
Call the Phone.
I do hope this helps I struggled for about an hour before I figured out it would SHOW the buttons but not allow them to control the phone...
Too much tech is annoying.
