05-09-2023 23:32
05-09-2023 23:32
I was using fitbitpay well and recently it decided to not detect my card in wallet.
I have removed the card to which I would like to troubleshoot but in the end I couldn’t even add any card, just receiving payload error 6200 upon pressing get started in wallet app.
Please help to solve the issue.
05-12-2023 13:42
05-12-2023 13:42
@bunnmeow Another idea: see if you have a device lock PIN already set up and try to remove it or change it. You can find this by tapping on your Profile photo > Sense > and scroll to the bottom where you see Device Lock. Try changing the PIN or see if you can disable it.
If none of this works, I'd try a complete factory reset of your Sense, remove it completely from the Fitbit app and your bluetooth, and set it up all over again like a brand new device.
05-12-2023 08:14
05-12-2023 08:14
@bunnmeow What kind of card are you using? Is the bank still supported? I would try uninstalling your Fitbit app and reinstalling it to see if that fixes the issue.
05-12-2023 08:29
05-12-2023 08:29
Hi @Heather-S ,
Debit card supported bank, it was working fine in the first year. Only recently I am totally unable to use the wallet app. The fitbit app on phone has been uninstalled and install back, it still show the same error prompt.
05-12-2023 13:20 - edited 05-12-2023 13:25
@bunnmeow Are you using an Android or iOS? I'm wondering if you're on Android if you have to use Google Pay now. See Google Pay comes up for you:
05-12-2023 13:42
05-12-2023 13:42
05-14-2023 03:07
05-14-2023 03:07
The device pin was in disabled state.
Everything worked after factory resetting, the watch and fitbit application.
Guess there was a bug after using the watch for a year.
05-14-2023 23:17
05-14-2023 23:17
Turn off and on the Bluetooth on your phone. On your phone's settings tap on Apps > Fitbit > Storage > Clear Cache. Go back one screen and tap on force stop. If possible, use another strong internet connection.
Regards,
Will
