08-04-2021 15:41
08-04-2021 15:41
Has anyone been able to find the actual units for the EDA sensor? I was able to find the raw readings by downloading my achieve, but there are no official units listed. The column is labeled as SCL which I presume to be skin conductivity level, so it is likely in siemens or mhos but there is no information in the ReadMe or the table.
Best Answer08-15-2021 10:44
08-15-2021 10:44
Hi @dev4906.
Unfortunately it seems that Fitbit doesn't publish such data. Perhaps a Moderator might be able to find some more information on the units involved.
