11-29-2021
06:20
14:53
LizzyFitbit
11-29-2021
06:20
14:53
LizzyFitbit
Do I just have a bad watch or did Fitbit whiff on this? Fitbit Sense is set to strong vibration but is super weak. Fitbit Versa that I was replacing with this sense had much stronger vibration (low setting on it was still stronger than the strong setting on this). Vibration is too weak to depend on it waking me in the morning, so having to use a physical alarm that wakes my wife also (old Versa was plenty strong). I found another thread that indicated others were having this issue as well. Is there something I am missing (second set of settings maybe or something in alarms).
11-02-2022 21:44
11-02-2022 21:44
Still couldn't increase vibration time or strength to what it is. (On the highest it allows.
Best Answer11-05-2022 06:21
11-05-2022 06:21
Nope you are not alone, mine feels like a weak mouse trying to get my attention.
