12-25-2020
08:36
10:42
EstuardoFitbit
12-25-2020
08:36
10:42
EstuardoFitbit
Mine and the wife fitbit sense will not connect to wireless unless there is no password. I tested and confirmed this, if WPA2 encryption is active it simply will not connect. Turn off authentication and it magically connects.
- I know the wifi password is correct
- I have turned off bonded networks 2.4GGHz/5GHz
- I have made sure mac filtering is off
- I have made sure I my device is on the same 2.4GHz network
- I manually created the network with WPA2 auth and it fails to connect
There must be a bug in the software when it's trying to make the connection, it's passing the wrong password, please fix this. You can't expect people to use guest networks with no authentication.
