I'm occasionally waking up with crazy step counts. This morning 6300, other days 12,000. This is NOT a timezone or midnight reset issue. Nor am I sleepwalking 5 miles.
Is there a way to resolve? Or a way I can reset my step count in the morning to zero?
Hi, @SanDiegoMike, welcome to the community, you will see this issue is occasionally reported. You may find this article useful How do I add, edit, or delete Fitbit data and activities?
I hope this helps.
Cheers
Gr4ndp4 | UK
Best AnswerThey say wind vibration from a fan can trigger the step counter? Also there is a sleep sensitivity, section under app settings in app, if not set to normal, not sure how that plays, with the step counter though
Best AnswerHi, @SanDiegoMike, a question, are you using "MobileTrack" Can I use more than one Fitbit device with the same account? see the section concerned.
Cheers
Gr4ndp4 | UK
