12-28-2020
01:21
10:46
EstuardoFitbit
12-28-2020
01:21
10:46
EstuardoFitbit
I got a sense for Christmas, set it all up. Set watch to vibrate when receiving texts and calls, but it won't vibrate.
Help please.
12-28-2020 03:25
12-28-2020 03:25
@Becky1980 Hello! Double check that it is connected to your bluetooth. Are you on Android or iOS?
12-28-2020 04:23
12-28-2020 04:23
Hi Heather,
It's connected to bluetooth, the calls and texts come through but my watch won't vibrate. Had turned on the vibration to on.
I have an android.
Thanks,
Becky
12-28-2020 05:40
12-28-2020 05:40
1. Vibrate is very feeble, even on strong
2. Make sure watch is not in sleep or quiet mode
Its very easy to enter these modes accidentally after a swipe right.
Do a swipe left and enter Settings and review each one.
BTW you can move the icons about to make Settings the first icon. Hold and drag it to first position, as you may be using it a lot to start with
