Hi, @EHammar , all currently available Fitbits are rated as water resistant to 50 metres depth.
The Pixel watch has this additional information (which I think also applies to all Fitbits, and is definitely worth noting, particularly the point about water resistance may be lost over time due to normal wear and tear. I remove mine for swimming, especially in salt water,
Designed to withstand the pressure exerted by 50 meters (5 ATM) of water. Designed to comply with water protection ratings of 5 ATM under ISO standard 22810:2010 when manufactured, but it is not waterproof. Water resistance is not a permanent condition and decreases or is lost over time due to normal wear and tear, repair, disassembly or damage. Dropping your Google Pixel Watch may result in loss of water resistance. Google Pixel Watch is designed to be used in shallow water and should not be used for activities involving high-velocity or high temperature water. Some accessory bands are not water-resistant.
