Is there a way to remove it from the clock face as well? I don't care if I can't uninstall it as long as I don't have to keep the widget on the Fitbit itself.
@SunsetRunner- unfortunately don't think removal is possible, however you can configure the widget not to show when you swipe up.
Probably best to contact Fitbit Support directly. They may be able to tell you and if so post back, it may help others..
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support
