11-13-2021 14:18 - edited 11-13-2021 14:29
On my Sense, the past week my weather app isn't working. It is giving me an error that "no location information. Go to fitbit mobile app to set up weather." I have been into the app and erased the information and redid it and it still gives the same error. Everything is set up correctly. I have restarted both my phone as well as my Sense and still the same. Also every permission says always not while using the app. Anyone have this happen on their Sense???
Best Answer11-13-2021 14:51
11-13-2021 14:51
I am having the same problem. I tried everything you did and still no resolution. It was working fine for awhile but recently stopped because it doesn’t recognize my location.
Best Answer11-13-2021 16:33
11-13-2021 16:33
Look at the permissions on the weather app. Also, you might again have to add your city.
Best Answer11-13-2021 17:46
11-13-2021 17:46
I have the same problem. Very frustrating
Best Answer11-13-2021 17:57
11-13-2021 17:57
I have already done all of this. I had put that in my post above
Best Answer11-13-2021 19:07
11-13-2021 19:07
I have a fix!!!! Delete your fitbit from you mobile app and then readd it. My weather app started working again right away!!
Best Answer11-14-2021 06:25
11-14-2021 06:25
Well apparently that didn't last long. It worked and then it stopped working again this morning. Sorry...
