07-09-2022
16:40
06:43
07-09-2022
16:40
06:43
My Fitbit SENSE says “ No weather data available. Sync the Firtbit Mobil app to update. Under the words is a 1/3 Blue screen that has a picture of a phone and an arrow pointing to the right (slide) then the word OPEN?
Nothing happens and I’ve reloaded my device, recycled my iPhone and I also downloaded a fit bit compatible weather app?
Best Answer07-09-2022 21:17
07-09-2022 21:17
Hi @CharlyHorse - even if you restarted both watch and phone make sure they are syncing in the Fitbit App.
Then click profile photo, device photo, gallery tile and scroll down to the weather app, and check permissions and settings, try removing cities and use current location.
Then sync again.
