11-25-2020 04:56
11-25-2020 04:56
Wow, I thought I'd got the "Big One" late last night, but it turns out to be 44.128.4.15, whatever this is? No Google Assistant, no audio, no improved Sp02 clock faces or anything. It was supposedly an update, but I cannot tell as it has done anything??
Best Answer11-25-2020 06:37 - edited 11-25-2020 06:39
You have to set up the assistant in the fitbit app under voice assistant.
on wrist calls have to be set up on the device through settings. You'll need to turn on "sense controls" which is under vibration and audio, and then music and on wrist calls.
you have to turn on sense controls, then go to your phone's Bluetooth settings and pair it.
There are currently 3 spo2 watch faces available now, more on the way by December.
11-25-2020 07:28
11-25-2020 07:28
I don't have any of these after this update.
Best Answer11-25-2020 07:55
11-25-2020 07:55
Do you have the most up to date app version on your phone? I believe that is required to unlock these new amazing features on the Sense.
Best Answer11-25-2020 13:04
11-25-2020 13:04
Look in Apps and install the SpO2 Tracker, if not installed.
Best Answer11-25-2020 13:38
11-25-2020 13:38
On the tracker. Settings - About Sense - 44.128.4.15 for version.
Best Answer11-25-2020 16:21
11-25-2020 16:21
it might have to do on your location. Suggest to check your location in your profile? Just a thought...
