12-12-2021
01:09
17:05
LizzyFitbit
12-12-2021
01:09
17:05
LizzyFitbit
When will each be available in the Isle of Man. My Sense shows location as United Kingdom bit I keep getting the "oops" message
Moderator Edit: Clarified subject and updated label
12-13-2021 07:48
12-13-2021 07:48
Hi, @MoFizz , welcome to the community, I can confirm the ECG works properly here in Northumberland. I do see it is supported in Ireland as well and suspect your problem is an un-noticed location issue. I suggest you talk to "Customer Support" here, use the chat facility or phone for a prompt response. You could also make the point at Fitbit Community where you can put forward suggestions.
I hope this helps, you should certainly have access to ECG in the IOM.
Cheers
Gr4ndp4 | UK
12-13-2021 07:48
12-13-2021 07:48
Cheers
Gr4ndp4 | UK
12-14-2021 06:04
12-14-2021 06:04
Thank you for your comments and suggestions. I am currently in email conversation with the Fitbit team but they haven't yet come up with any answers. There seems to be a problem with my physical location being the IOM and the location determined by the automatic location on the Fitbit app being the UK.
Maybe the software developers need to deal with this anomaly as a matter of priority. I really hope they get a solution soon.
All the best.
Best Answer10-07-2022 05:19
10-07-2022 05:19
I have signed up to Premium service in order to use the ECG app but need to reconsider now.
also based in Isle of Man but have all my locations set to UK
06:28
05:21
10-07-2022
06:28
05:21
Hello @IOMfit and welcome to the Community. First, the ECG app doesn't require Premium, so you should continue your Premium service based on its features. I'm in the US, but this post caught my eye and I wanted to learn more about the IOM. I think this issue comes from the IOM's status and I found my explanation in this article: The British Island that's not in the UK The ECG app needed to by approved by the US FDA for approval here. It got released in the UK when it was approved by the MHRA. I think this is a governmental technicality -- does the MHRA have jurisdiction on the IOM?
Some users wrote that using a VPN blocks the location and lets you use the ECG.
Laurie | Maryland
