Will it be okay to wear the Sense on ankle?
ANSWERED
Anyone got a better solution for me? Work in Healthcare and need to be bare below elbows at work. Previously had v. old fitbit which i attached to belt loop on work trousers - counting all steps 😉.
New Sense and happy with it but felt should attach to ankle as bulkier for trousers and then can still get other health metrics. Luckily wearing trousers😂. Worried that have to change from small to large strap and back each day - will the Sense be ok with this changing daily?
1 BEST ANSWER
Accepted Solutions
I’ve been doing that, @Gill81, without a problem . The longer Sense band allows me to place the Sense at my ankle when using my recumbent exercise devices. I place it over the muscle at the inside, just above the ankle bone. This allows the device to still capture heart rate. But keep in mind, this is not the way the device was designed to be worn. It may skew some of your data but it works for me. You have to do what you have to do.
2 REPLIES 2
Only the user can make this decision for them self.
