02-11-2022 14:07
02-11-2022 14:07
First time I have used my Fitbit Sense in a pool (no deep end). I was in the water a total of 20min and noticed that it stopped working. I dried it off and set it in the shade to dry for 3hrs then charged it again. Still won't turn on! Apparently they are not pool proof or waterproof to 20m as advertised.
02-12-2022 17:16
02-11-2022 21:24
02-11-2022 21:24
Yes they are but you have to put the swim lock on before you take a dip in the pool. Good luck, hope you can get it replaced. Since it wasn’t clear on the instructions.
02-12-2022 07:06
02-12-2022 07:06
02-12-2022 08:04
02-12-2022 08:04
02-12-2022 17:16
02-12-2022 17:16
02-12-2022 19:08
02-12-2022 19:08
Swim lock has nothing to do with your case. The lock just blocks touch input in the water. Watch is water resistant regardless. If your Sense died in the water it's a hardware failure and only you can do is contacting customer support.
