04-25-2021 07:59
04-25-2021 07:59
ecg function is still not available in my country, im wondering if i would still be able to get an alert if my heart rate is irregular? ( im buying it so i could monitor my anger -heart rate goes up when this happen)
Best Answer04-25-2021 10:25
04-25-2021 10:25
In the app, go to account/activity & wellness/heart setting/high & low heart rate and turn on high heart notification. You can go with the default settings or create custom settings.
Best Answer04-29-2021 04:34
04-29-2021 04:34
I dont have the FB Sense yet but really want it. My country does not have the ECG spec yet.
Is it possible to set alert for irregular heart rate without the ECG spec?
Best Answer04-29-2021 06:08
04-29-2021 06:08
@linasense The Sense has a high and low heart rate alert. It doesn't have an irregular heart rate alert. These heart rate notifications are described on p 58-59 of the Sense Manual.
Laurie | Maryland
Best Answer04-29-2021 09:12
04-29-2021 09:12
Best Answer04-29-2021 09:30
04-29-2021 09:30
@linasense These alerts can tell you if your heart rate is faster or slower than the limit you set. It cannot tell you if your heart rate is regular or irregular. The ECG app is not an app that runs in the background. You start the app and take a measurement while holding the edges of the Sense frame with your other hand. You get one of three results: normal rhythm, atrial fibrillation, or inconclusive.
Based on what you wrote in your initial post, the Sense can't tell you what you want to know.
Laurie | Maryland
04-29-2021 09:44
04-29-2021 09:44
Best Answer04-29-2021 16:14
04-29-2021 16:14
@linasense These measurements come from the heart rate sensor — the green LEDs. It doesn’t use the ECG app.
Laurie | Maryland
Best Answer04-29-2021 17:51
04-29-2021 17:51
