01-24-2022 10:46
01-24-2022 10:46
"exercise shortcuts" is missing from my fitbit sense app menu and I want to add Rowing Machine to my exercise list I have followed a tutorial on how to get to exercise shortcuts on the mobile app but its missing from my mobile app.
I want to remove run and add rowing machine, I'm disabled and will never be able to run. can some one please advise me how I can update my sense to better suite my exercise needs. I need Yoga, weights, Spin bike, and Rowing Machine please then Workout, Pilates, Walk and out door workout.
01-24-2022 11:15
01-24-2022 11:15
On the Sense (and Versa 3), exercise shortcuts are all on the wrist rather than on phone app. From main clock face, scroll right through apps to Exercise and tap that. All of the options will be listed there as you scroll down through the list. They are generally in alphabetical order, but the last 3 you have used will always be at top, so easier to get to. If you commonly use more than 3, you will have to scroll down through the list for some, but that is quite fast. There is no way to remove any from the list, as unused ones generally stay away from top of list. Rowing is not on the list and cannot be added, but Fitbit suggests using 'Workout' if you cannot find something close to our activity.
You can read more at How do I track my workouts with my Fitbit device?
Best Answer02-08-2022 18:00
02-08-2022 18:00
Having the same issue. There is nothing there when I tap the app.
02-09-2022 00:29
02-09-2022 00:29
