12-07-2021 11:05
12-07-2021 11:05
how do I delete an exercise from the list of 7 on my sense watch
12-07-2021 11:31
12-07-2021 11:31
On your phone app tap on your profile picture (upper left corner) to bring you to the settings page. There tap on the Sense tile to get to the device settings. Scroll down to Exercise shortcuts and tap that. You should see the list of activities. Swiping left will remove that exercise from the list. The plus sign at the top right is to add exercises.tapping and holding the bars on the left of the exercise will allow you to move that exercise up or down.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
12-08-2021 07:33
12-08-2021 07:33
Ionic have this but not Sense
12-08-2021 08:28
12-08-2021 08:28
Sense doesn't have the 7. They're alphabetically listed with recents sticking at the top for a few days.
12-08-2021 09:52
12-08-2021 09:52
Hi, @James.P, @wtksk8r is correct, This video demonstrates the process on a Charge 4 but it's just the same for a "Sense" as the adjustments are made in the Fitbit app on your phone. I hope this helps.
Cheers
Gr4ndp4 | UK
12-08-2021 20:04
12-08-2021 20:04
Hi @Gr4ndp4, unfortunately I still cannot see such settings on Sense. I find it troublesome too for it to unable to reorder the favourite exercises to my preferences. As @TommyIzzo had also shared, this adjustment is not available on Sense.
Good for you though that you can reorder the exercises. Probably shows fitbit apps has some disparity on their apps interfaces.
Thanks for sharing the video as well
12-09-2021 02:50
12-09-2021 02:50
I did what you said but on my iPhone Sense app Exercise Shortcuts is not there.
12-09-2021 04:38
12-09-2021 04:38
Hi, @James.P, these settings are not on the "Sense", they are in the Fitbit app on your phone. I'm not familiar with the IOS app but there may be something in this thread iOS App - Fitbit Community
I hope this helps.
Cheers
Gr4ndp4 | UK
12-11-2021 21:28
12-11-2021 21:28
Yeah I understand but the settings simply isn't available for my fitbit apps on the phone.. not sure why there are differences
