My FitBit Sense stopped syncing. I was able to sync my device by hard-pressing the side button until I saw the FitBit logo then releasing. But that doesn't work anymore. How else can I sync my Fitbit sense manually?
09:19
03:43
05-31-2022
09:19
03:43
Hi @gymrat54 - if you have sync problems often restarting the phone too helps resolve it.
Another quick option that can work, is pull down on the Fitbit App screen
If it sn't syncing, try
You can also delete the Bluetooth entry before logout and then it will make a new pair which sometimes helps.
