04-26-2021 10:03
04-26-2021 10:03
My Sense gives me the message "Sync the FB mobile app to get weather". I sync my FB everyday but no weather. What should I be doing?
Best Answer04-26-2021 10:39
04-26-2021 10:39
when you have the app open well after you sync the watch in the app then open your watch scroll up just slightly were it says weather clik it might say no weather data available wait like 4 seconds clik that message again see if it connects to your phone weather app it should sync up then fyi i believe it only holds about 8 to 12 hours worth of weather info so you would need to do this twice a day if you want the weather to be accurate on the watch. I noticed this is dependednt on your phone settings which settings i don't know as i have used a friends phone for sevreal days and the weather stayed connected the intire time with his phone so i hope this little bit of info helps you out I know it confusing info from me lol
