12-06-2020 03:58
12-06-2020 03:58
Ever since this last update that adds spo2 tracking every night I went from getting about 5 days per charge to less than 3 days. Are there any fixes for it?
12-06-2020 05:34 - edited 12-06-2020 05:36
Hi @wookietim.
Yes uninstall the spO2 app (of course if you're happy with not tracking it). With the spO2 app my battery life is around 4 days, without it 5-6 days.
I've also heard some users have had luck with turning off the permissions in the spO2 app, and only enabling the permissions when they want to track spO2 for that night. Without the permissions the app doesn't run, therefore not draining any battery. It's also easier than uninstalling and reinstalling all the time.
Hi @wookietim.
12-06-2020 08:15
12-06-2020 08:15
How do I disable spo2 permissions? I was okay with tracking it only once every few days... it rarely changes beyond 95 or 96% anyway.
12-06-2020 08:22
12-06-2020 08:22
Derp never mind - go to the app and click on permissions.
12-06-2020 13:42
12-06-2020 13:42
Glad to hear you found it. Hopefully this will solve the drain for you.
12-06-2020 14:55
12-06-2020 14:55
So true...i've been monitoring SPO2 levels for about a week and a half, it does rarely change. I'll keep it on and just charge the Sense after getting an email that the device needs charging. I get about 3-4 days with SPO2 engaged.
12-07-2020 04:46
12-07-2020 04:46
If it helps anyone any - turning off permissions REALLY increases charge life.
I had to charge yesterday. Took it off the charger at 6pm. With it turned on by this morning it'd be down to at best 85% and more likely 80%. Instead it's at 92%.
06-04-2021 23:01
06-04-2021 23:01
I have uninstalled everything I know. After the update I am only getting 12 hours battery life. What else can I uninstall
