10-05-2022 15:56
10-05-2022 15:56
My Fitbit sense will not turn on or charge. I have tried the hard reboot, multiple, multiple outlets, usb ports, charging cubes, different cords and it will not do anything. I just received this in June and am devastated that it has stopped working. Please help!!!
10-05-2022 18:19
10-05-2022 18:19
Mine, too…. My Sense isn’t charging. I have 25%
10-06-2022 03:52
10-06-2022 03:52
Hi, @suelloyd82 & @glo88jac use the search bar to look for posts about charging your "Sense" Briefly check the 4 pins on the charging cable puck, clean the back of your "Sense" and charge for at least 60 minutes. If you see the "Slow Charging" message on your "Sense" give the puck a little wiggle to improve the pin contact and put it down gently in order to avoid disturbing the contacts. Why isn't my Fitbit device's battery charging? also provides advice.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
10-06-2022 06:49
10-06-2022 06:49
Mine has done the same thing! It will not charge anywhere. It is dead. I bought it in January & I loved it until now. They need to have repaceable batteries!
10-06-2022 09:14
10-06-2022 09:14
Hi, @TrishObx, have you followed the steps I suggested? Let us know how you got on.
Cheers
Gr4ndp4 | UK
10-06-2022 17:03
10-06-2022 17:03
Have had recharging issues too. I used an old toothbrush and sprayed a LIGHT amount of rubbing alcohol on the bristols and rubbed vigorously for 30 seconds or so. I concentrated on the ports where the pins insert. Fitbit Sense took a charge immediately.
10-06-2022 17:23
10-06-2022 17:23
10-06-2022 17:25
10-06-2022 17:25
I tried your advice but it’s still not charging… I’m so sad because I REALLY like my Sense
10-08-2022 05:04
10-08-2022 05:04
Same for me.
10-08-2022 05:09
10-08-2022 05:09
My Sense will not show a clock face. it will only show the Fitbit logo. I have tried doing the hard restart multiple times without success. Anymore ideas?
10-08-2022 06:33
10-08-2022 06:33
Hi, @Eagle55 & @glo88jac Allowing you have followed the advice posted earlier you should (as advised) contact "Customer Support" using the chat facility or phone for a prompt response.
Cheers
Gr4ndp4 | UK
11-01-2022 05:48
11-01-2022 05:48
I ended up contacting Fitbit customer service and sending it in to be looked at. Did you ever get yours to work?
11-01-2022 06:47
11-01-2022 06:47
