04-07-2022 16:12 - edited 04-07-2022 20:23
04-07-2022 16:47
04-07-2022 16:47
I found a different forum that suggested I do the following after my notifications stopped working:
1. remove both Bluetooth connections
2. remove the Sense from the Fitbit app
3. reset the Sense back to factory defaults - under “settings” in the watch
4. restart my phone
5. add Sense to Fitbit app - which adds both Bluetooth connections again and updates the Sense
6. enable notifications - which should be done by default
That should get you going again. It worked for me, but I will say that my Sense stopped answering calls after 2-3 weeks. My watch did run out of battery and died, so I don’t know if that had anything to do with it. Good luck!
04-07-2022 16:48 - edited 04-07-2022 16:55
https://help.fitbit.com/articles/en_US/Help_article/1979.htm
Note that Sense Controls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect.
04-07-2022 16:56
04-07-2022 16:56
As a follow up, I have also had to remove my sense controls Bluetooth connection, and go through the app to add it back in under “on-wrist calls”
04-07-2022 21:08
04-07-2022 21:08
Hi @Sabazan78 - did you try to swipe the watch face to the right to get to Quick Settings and make sure the sleep and do not disturb icons are not accidentally enabled.
04-08-2022 04:11
04-08-2022 04:11
What was the solution?
04-08-2022 06:04
04-08-2022 06:04
In the Bluetooth option there is a small i in a circle next to the sense connection. I had to select the “i” and turn on the “share system notifications” option. Now all the sense control options are working again. I can receive and answer phone calls and I’m getting text messages too. The sense control still shows “not connected” but as others have said, it does connect when a call or text comes through. Mine wasn’t working because i had turned off the “share system notifications” option.
04-08-2022 11:31
04-08-2022 11:31
ITS A GLORIOUS DAY and wonderful feeling!
Glad you got it sorted.
