02-12-2023 23:03
02-12-2023 23:03
The Fitbit logo is on screen and I cannot go back to the home screen. I deleted from bluetooth and it is no longer registering with my iphone - it is not finding the device. It seems to be frozen. I tried to force close and this did not work.
Best Answer02-12-2023 23:04
02-12-2023 23:04
Hi @geraldineables - it seems that something is freezing and it is time to restart the device.
Best Answer02-13-2023 00:15
02-13-2023 00:15
It is not allowing me to restart the device
Best Answer02-13-2023 00:21
02-13-2023 00:21
@geraldineables- what action are you trying to do that is not working?
Normally pushing the power button of a phone should work, it should give you options which you select and maybe confirm. if not try letting it run down completely.
Also for a watch see How do I restart my Fitbit device?
Best Answer02-13-2023 09:29
02-13-2023 09:29
Best Answer02-13-2023 09:37
02-13-2023 09:37
@geraldineables - perhaps you can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support. They can give you precise guidance.
