09-21-2022
11:05
11:39
09-21-2022
11:05
11:39
Can you enable GPS on the swimming exercise to allow tracking of open water swimming?
even if it is intermittent...and did GPS assumptions between intermittent points....it would be great for tri-athletes
I have moved your post to the Sense forum. Someone here should be able to help you with your device question.
Best Answer@madmax52 unfortunately, the open water swimming isn't supported. You may use Outdoor Workout but it lacks water lock so your watch will be performing random actions while wet. Only Swim activity has water lock on Sense but no GPS. Btw. a triathlete probably wouldn't use a Fitbit 🙂
