05-01-2021 09:52
05-01-2021 09:52
does anyone know how to turn off fitbit sense after factory reset? all the time there is a screen where the download fitbit application is displayed. I do not know how to turn off the watch in this moment
05-01-2021 15:10
05-01-2021 15:10
Do you see any change if you put it back on the charger?
Best Answer05-01-2021 17:13
05-01-2021 17:13
sounds like it needs to be reset up I would drop it from the fitbit app completely and redo the set up you know where the app asks you to inter 4 diget that set up what your seeing is the original blank watch interface no firmware it was reset back to factory settings so you will need to redo the original set up all over again don't worry you don't lose your info that all ready in the app hope this helps.
