06-29-2018 18:37
06-29-2018 18:37
Hi all,
Is there any way to export the precise start and end times of each stage of sleep?
When I export the sleep data in XLS or CSV format, it only gives the general start and end times and then the total times for each stage. I would like to be able to export the beginning and end times of each stage.
I like being able to track this in each day's graph, but I was hoping to get the raw data to try to write a script that could find patterns in the data, to try to predict when REM is likely to occur.
Is there any way to do this? Any help is much appreciated. Thank you!
