11-19-2017 05:58
11-19-2017 05:58
I am constantly tired. I wake up and the first thing is when am I going back to bed to sleep . I have tried to upload my last night Fitbit sleep results (but failed) - is there any one who would take a look at see if these are any were in the "normal" range.
11-19-2017 07:07
11-19-2017 07:16
11-19-2017 07:16
Here are some of my nights tracking - I have tried to keep as many constants as possible. Same Fitbit settings, same bed almost same temp etc The 3 hour sleep is the most “average”. The 5 hours was last night - and to be honest I fee just - if not more tired than usual -
many thoughts would be hreatfully revived
11-19-2017 08:10 - edited 11-19-2017 08:10
11-19-2017 08:18
11-19-2017 08:18
Have vaguely heard of this - via the NHS or private ? Can you suggest any ? Any internet resources to recommend ?
99% of my Fitbit sleep readings are the same as this -
Thank you
11-24-2017 23:48
11-24-2017 23:48
Hi one thing that stands out to me is bedtimes aren't consistent. There may be other factors as to why your not sleeping well.
11-25-2017 00:21
11-25-2017 00:21
Ok, noted - my job means that some times I finish work at different times.
I am so tired that I need to have a sleep in the afternoon. I have tried to fight through it - but I don't sleep any better at night if I do and I get more and more grumpy as the days go by. I know thats bad sleep hygiene but if I do, I fatigue fast.
11-25-2017 01:07
11-25-2017 01:07
I understand what your saying. You do get grumpy because your running on stress hormones. It becomes a viscous circle. Do you work shifts in your job. If so that would make sense.
11-28-2017 04:56
11-28-2017 04:56
First remove alcohol for a period. Also don't have coffee within 6 hours of bedtime. Then if it persists, see your GP and discuss. They will probably refer you to a sleep study.
My GP suspected sleep apnea and the symptoms were largely identical to yours. A sleep study confirmed and after a couple of weeks with my dental appliance, I'm sleeping a solid 6.5-7 hours a night, with no wakeups, and no afternoon naps. That was 7 years ago. If I don't have my dental appliance in, then I revert to the same old broken sleep pattern.
I'm not saying sleep apnea is your problem but a sleep study will tell your doctor what's going on.
