Sleep stages change on Charge 2?
Anybody else wake up today and notice it is the 'old' version that doesn't give much insight?   The sleep stages is the primary reason I use this (next to heart monitor).   Hopefully its 'fixed' soon as the old version doesn't really give much insight.
Micah
2 REPLIES 2
Fitbit suggest there are a few reasons this can happen:
"WHY DON'T I SEE SLEEP STAGES TODAY?
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
  • If you slept in a position that prevented your tracker from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your tracker higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your tracker to bed). For more information on automatic sleep tracking, see How do I track my sleep?
  • If you slept for less than 3 hours.
  • If your tracker’s battery is critically low."
taken from: https://help.fitbit.com/articles/en_US/Help_article/2163
I had the same, its been using the Sleep stages for about 3 weeks now, but for some reason last nights one went back to the the pattern mode.  The sleep monitoring is the main reason i use the fitbit so having it go back to the old setting isn't good
