09-21-2020 06:41
09-21-2020 06:41
Hi!
I have a couple easy questions for you:
1. What is the green star to the right of my sleep log?
2. My "Estimated Oxygen Variation" zig-zag line runs roughly ½ way between the two horizontal bars. Is that low? The green line never touches either the high or low horizontal bars.
Thanks!
Michael
P.S. How do I insert an image of my Estimated Oxygen Variation? The icon wants to know about the image but doesn't have the expected location finders to choose the image.
Best Answer09-21-2020 07:18
09-21-2020 07:18
1. Green star means you met your goal for amount of sleep.
2. As long as the line is green and below the 'High' line, that means your EOV is low (or at least not high), which is good. When line goes above 'High', graph turns yellow, at least on Android - can't guarantee graph looks same on IOS.
3. To insert picture/screen cap, click camera icon above input box, then 'Choose Files' lets you select the location on your computer where file is located.
09-21-2020 07:18
Best Answer09-21-2020 09:36
09-21-2020 09:36
Thank you, JohnnyRow. Here's the photo I wanted to paste before. How does my O2 look to you?
