08-21-2014
14:40
07:49
08-21-2014
14:40
07:49
Hi all! Shameless plug here:
I've recently written an article regarding sleep tracking. I was sure to include notes regarding tracking sleep with each tracker, manually logging sleep, and more!
You can view the article, as well as provide feedback, ask questions, etc. here.
I look forward to hearing from you all! ![]()
Best Answerhi
read your article re sleep tracking and was fascinated by the graphs. even though I have the setting at sensitive my reports/graphs indicate sleep and awake only! I use a laptop with windows 7. is this a me problem, a computer problem or a fitbit problem? have had my fitbit for nearly 3 weeks now.
hope you can help.
regards
suem1
20:35
07:49
11-14-2014
20:35
07:49
@suem1 I have Fitbit Connect on my Windows 7 nd 8 laptops without a problem. My sleep is set for sensitive and non-dominant. Do you see any restless times in your sleep pattern?
Welcome to the forums.
Best Answeram set for sensitive and nondominant. I only see wake and asleep. have noticed no light comes on when I'm syncing.
16:57
07:49
11-15-2014
16:57
07:49
@suem1 To see your sleep time, you looking on the dashboard or on the log area for sleep?
It doesn't light up when you sync.
Best Answerthanks for responding odyssey13.
I've been looking in trhe log area for sleep.
my graphs are 2 colours only - the awake and the sleep colours
regards
suem1
Best Answer@suem1 I just took a look and found the graph with sleep, awake and restless.
Go to the dashboard, click on the "quick view" on the sleep portion and you'll see all three.
thank you for your help. I found the graph I was looking for. I really appreciate you taking the time out to reply.suem1
