09-23-2021
07:47
09:17
BraulioFitbit
09-23-2021
07:47
09:17
BraulioFitbit
I am an octogenarian. I use my fitbit to keep track of my sleep and to have a speedy way to check my oxygen and heart rate.
I also need one with a band that will convert to a simple magnetic band because with arthritis it's impossible to get the hooks through the notches of a traditional watch like device.
What is my best bet? I don't care about steps or intervals or anything else: just sleep and heart rate.
Hi, @Provis. I hope you're doing well!
Based on what you're looking for, I believe that the best option could be the Charge 5 (you can click here to find out more about it). With this device you can track sleep, heart rate and your blood oxygen level. Even though Charge 5's band is a watch-type wristband, you can buy a Hook & Loop band:
This band is easier to hook on your wrist since at this moment we don't have a magnetic-type band. This band can also be bought on our web store.
Hope this information helps on your decision.
