01-19-2025 08:27
01-19-2025 08:27
Instead of sleeping stages (deep, rem etc.) it shows "sleep quality ( awake, restless, asleep). Why? What should I do to see sleeping stages again?
Best Answer01-24-2025 05:32
01-24-2025 05:32
I fixed my issue by turning off bluetooth on my phone, restarting my watch and then turning on bluetooth back on. This morning I had sleep scores and the graph back. Hopefully this quick fix will work for others.
01-19-2025 14:01 - edited 01-19-2025 14:03
Hello @Remme1
Sorry to see that you're getting only the basic sleep graphs and not the graphs with the sleep stages.
This Fitbit help page (<-- click link) has the recommended troubleshooting steps to try when you aren't seeing sleep stages.
By any chance are you also having issues with heart rate tracking? Do you see a green light on the back of your Fitbit device? The green light is the heart rate sensor and is needed for sleep tracking.
If you don't see the green light, let us know which Fitbit device you're using. We might be able to suggest ways to get your heart rate sensor working.
Best Answer01-22-2025 06:09
01-22-2025 06:09
Mine has stopped as well, no stages or scores since January 9th. The new screen offers very little information. The linked page in the response to the original post doesn't address this issue.
Best Answer01-22-2025 10:36
01-22-2025 10:36
No issues with heart rate tracking. The green light is there
Best Answer01-22-2025 10:39
01-22-2025 10:39
Mine stopped 13. Jan😒
Best Answer01-22-2025 12:05
01-22-2025 12:05
My heart rate tracking works as well and it also tells me how long I was asleep but that is it.
Best Answer01-22-2025 14:48
01-24-2025 05:32
01-24-2025 05:32
01-25-2025 00:34
01-25-2025 00:34
Thank You! It really helped😊
01-26-2025 06:26
01-26-2025 06:26
I'll give it a try, thanks.
01-27-2025 11:05
01-27-2025 11:05
I tried this and it worked! Thank you!
