02-05-2023 03:50
02-05-2023 03:50
Two nights in a row I have no sleep info. Everything else records fine. Anyone else have this issue?
02-06-2023 16:37
02-06-2023 16:37
I am having the same trouble with mine also. I don't know how to fix it and would like to know also. I hope we can get this fixed.
Best Answer02-07-2023 10:59
02-07-2023 10:59
I’m having the same issue with my Versa 3.
02-07-2023 11:20
02-07-2023 11:20
Our (my gf and I's) Inspire 2s just started having the issue as well. I'll spare you the support schpiel about putting it on your non-dominant hand and disconnecting/reconnecting to bluetooth because it's clearly a widespread issue not your device. But I did reboot mine earlier today and so hopefully it will properly track tonight's sleep.
02-07-2023 14:17
02-07-2023 14:17
I did disconnect and reconnect. It is working now. I have a older model a Charge 2. I do have to recharge the battery a lot, 3 or 4 times during the day. I was wanting to buy a newer model, but it seems like they are the same problems. I don't think buying a newer model with the same problems is worth it. I have always wore it on my non-dominant hand. I saw on QVC where I got this one the reviews are low for all the models there.
